HWiNFO64 Plugin for Rainmeter Ideas
jgiels
[attachment=1476]
I have been working on getting some skins to work with this plugin and was having some well continuing difficulty in having the skin read sensor values. It seemed that for a time they would work and then the next day they would not.
I had always thought that the HWiNFO.inc file that resided in the HWinfo skin would then work for all other skins. Once I had configured the sensor ID's. Though I have found this is not the case. Each skin uses the HWiNFO.inc file that resides in its own @resources folder.
While using the varialbles @Include=#@#\HWiNFO.inc  doesn't seem to make a given skin go to the HWiNFO skin that has the first HWiNFO.inc file.
So to get my skins to work consistently I used the Variables  @IncludeSensors = #@#\HWiNFO.inc. While configuring the file that resides in the current @resources folder of the given skin.
thanks.. Douglas
