Paravirtual
I've tried Rainmeter and HWInfo Monitor Gadget, and appreciate both of them. Rainmeter is much more flexible and you can create far more satisfyingly beautiful displays with it, but I find that tweaking it is pretty time consuming and it takes longer to achieve a nice effect.
And so, I still like the old school Gadget, and still run it on my main Windows 10 Workstation
Below is what it looks like when Idle. CPU will go up to 4.8Ghz @ 1.2Vcore, tops out around 76 Watts, which is pretty modest. It's much more efficient than my other box...
I also have a Server box that I want to monitor Temps and CPU utilisation on, and set about setting up something similar. The box runs the Desktop-Experience variant of Server 2019 (I might otherwise have used Server Core but there are still just a handful of things I want to keep that GUI for, and it's got plenty of spare resources)
It's older hardware, but still has good support in HWInfo; a Tyan S7012 with Twin Quad Core Xeon L5630, for a total of 8 Cores, 16 Threads, at around 2.3Ghz. Less overall performance than the i7 and draws more Power both when idle, and under load. Still a decent old workhorse, plus it's loaded with 18 (yes, 18) lots of 4GB ECC RAM (because DDR3 ECC is cheap and board has 18 slots) so it has its uses.
Anyway, back to the point; I cannot get the gadget to work properly on this server. Shared Memory is enabled, Sensors are running. I have Rainmeter+ModernGadgets running and it can read the sensors just fine so long as I don't untick shared memory or close Sensors instead of minimising, so I know that the shared mem stuff is working, and can break/fix this easily at will.
I'd rather use the Gadget if I can. I prefer my way around the config (when it works)
But the HWInfo Gadget, won't detect HWInfo running at all. It's behaving as if I had not enabled Shared Mem / Not running Sensors, even though I know I am as Rainmeter's talking to it OK.
Does anyone have any idea why Gadget might be failing here? Is there something about Sever 2019 that might handle access tot he shared mem differently, in some way? I just can't work it out.
Any other ideas?
Any other ideas?
