I have an ASUS ROG Zenith Extreme (latest firmware rev. 2001) with 2 RAID arrays. One array is detected fine. It has 5 drives in a RAID 10 configuration (4 main drives and a hot spare). The second array is actually my boot drive. It has 2 M.2 SATA drives in RAID 1 configuration. In RAIDXpert2, the drives and arrays are identified and listed correctly. But in HWiNFO 611_3890, it's not identifying the second array, lumping the 2 RAID 1 drives under the other array, and displaying garbage for one of the drives:
Note the corrupted drive description and incorrect information, that it's in the wrong RAID set, etc.
The other M.2 SATA drive is identified correctly, but is in the wrong RAID set as well:
Žd [1:5] |
[General Information] | ||
Drive Controller: | IDE | |
Host Controller: | AMD-RAID Controller [storport] | |
Drive Channel: | Tertiary, Slave | |
Drive Address: | RAID Set #1, Disk #5 | |
Drive Model: | Žd | |
Drive Firmware Revision: | ||
Drive Serial Number: | ||
Drive Capacity: | 520,893,633,658,880 MBytes | |
Drive Capacity [MB]: | 520893633658880 | |
ATA Major Version Supported: | ACS-3 |
Crucial_CT1050MX300SSD4 [1:6] |
Drive Controller: | Serial ATA 6Gb/s @ 6Gb/s | |
Drive Address: | RAID Set #1, Disk #6 | |
Drive Model: | Crucial_CT1050MX300SSD4 | |
Drive Firmware Revision: | M0CR060 | |
Drive Serial Number: | 18021A88C6BA | |
World Wide Name: | 500A7511A88C6BA | |
Drive Capacity: | 1,001,562 MBytes (1050 GB) | |
Drive Capacity [MB]: | 1001562 | |
Media Rotation Rate: | SSD Drive (Non-rotating) | |
Nominal Form Factor: | <1.8" | |
ATA Major Version Supported: | ATA/ATAPI-5, ATA/ATAPI-6, ATA/ATAPI-7, ATA8-ACS, ACS-2, ACS-3 | |
ATA Minor Version Supported: | ACS-3 Revision 5 | |
ATA Transport Version Supported: | SATA 3.2 |
