Incorrect sensors readings (GIGABYTE GA-B150-HD3)
oldman777
Hello Martin.
First of all would like to thank you for this great program.
My motherboard (GIGABYTE GA-B150-HD3) almost all of the sensors in HWINFO are incorrect readings (voltage, temperature, etc.).
In my motherboard BIOS/UEFI all of the sensors readings correct.
Screenshot, HWiNFO64.DBG  and HWiNFO64 Report File:
[attachment=2041]
Thanks in advance.
  • GIGABYTE GA-B150-HD3.7z
Thanks for your report. Can please also attach a screenshot of GIGABYTE EasyTune tool showing all sensor values, so I can adjust them properly in HWiNFO ? Best would be a side-by-side screenshot with HWiNFO.
Install any utility separately, it impossible now. First you need to install (APP Center (Intel 100 series) and NET Framework 4.5.
I install (APP Center) and after (EasyTune), but there is now no sensors data - buttons for overclock only.
The sensors are located in separate utility - (System Information Viewer (Intel 100 series)
A pair of screenshots (System Information Viewer) and same in attachment:
[attachment=2042]
  • System Information Viewer.7z
Thank you Martin for your fix in Beta v5.39-3015, now seems all right. The only thing in doubt - Temperature 4 = 94° C
[attachment=2045]
Thanks for your feedback.
"Temperature 4" could be an invalid reading from a sensor which is not connected.
[attachment=2139]
[attachment=2140]
Hi Martin.
Suddenly found that it seems "Core #0,1,2,3 Distance to TjMAX" Minimum and Maximum values need to swapped. The Minimum instead of Maximum and Maximum instead of Minimum.
Thanks.
  • Report OLDMAN-PC.zip
