Invalid Sensor readings on Asrock B550 Phantom Gaming-ITX
MrCommunistGen
Yes, those are most likely invalid.
If you upgrade to the latest Beta build, it should tell you a bit more about the meaning and most likely that they are not guaranteed to be correct.
