Is there a way to combine graph view and sensor view into a single pane window?
Syntax Error
Big fan of HWInfo, the amount of sensors and graphs that can be displayed at once makes it a very useful at-a-glance single pane window of my most important system temperatures, clocks, and frequencies.
However one annoyance I have with it is that graphs and the sensor view are all separate windows. Normally this would not be an issue but I do also switch my monitor view from my usual dual screen setup to my television on a single screen if I am in the mood to couch game. However in doing so, all the windows get moved to the single window side and I like to have all the sensors on my secondary monitor when I am using my dual monitor setup.
Is there a setting anywhere to "merge" the sensors and graphs I have displayed into a single window? That would solve the issue and avoid the issue of having to resize and drag 12 windows every time I return to a dual screen mode on my computer.
I have attached an example of what I do with the sensors and charts on my second monitor - if this could be a single window with all the sensors and charts that would be most ideal. Right now it's 12 separate windows which makes it annoying to have to move to the second monitor every time I switch from a single monitor TV view to a dual monitor setup.
Thanks!
Sorry but such option is currently not available. You can however merge multiple graphs by using the new OSD function in Independent Window mode.
I would also like to be able to combine several regular graphs into one. I tried understanding the OSD feature, but I wasn't able to figure it out (and it says it needs to be installed in a special folder, but I'm using it portable so that's not an option for me).
