Is this Wrong Info on this Temp
Goutham A Nair
I installed HWinfo on my system. But the motherboard & AUXTIN1 & AUXTIN2 shows high Temp at over 100 degrees
Screenshot of HWinfo Temp
But the CPU temp is Normal & I check at Asus BIOS info Then I checked the temp
The Temp shows CPU is arround 30 to 32 degrees Celsius and Motherboard at 37 degrees Celsius
And what is this showing 111 &110 degrees Celsius.
Is this Bug or Not ?
Most likely an invalid readout from a not connected sensor. Please attach the HWiNFO Debug File for analysis.
