It is possible show temp for ssd but disable for hdd?
Yes, but hwinfo still check/scan hdd and prevent hdd to turn off while idle, disable Drive Scan helps, but it disables all drives.
I wanted check ssd temps, but disable hhd check/scan/monitoring.
If you disable monitoring of the HDD sensor then it won't scan the drive anymore.
Alternatively you can set the "Disk S.M.A.R.T. every" polling parameter in sensor settings to a very high number.
