massive recording errors
CB_acty
Hello folks, hello Martin,
I am at the end of my knowledge. I would like to record some system parameters (CPU-Temp tctl, DIMM Temp, SSD Tem, VRM Temp, GPU Temp and GPU Fan rpm) via HWInfo, which has always worked great so far.
With the current system, HWinfo (or the system) bitches around and records completely wrong values, while the values in the overview are output without errors.
System:
HWinfo 7.22-4731
CPURyzen 7 3700X, 65 Watt TDP
MainboardMSI B350 I Pro AC (neustes BIOS Update zur Unterstützung der 3000er Ryzen)
ArbeitsspeicherCorsair Vengeance RGB 16 GB DDR4-3200
GrafikkarteMSI Radeon RX 6700 XT Gaming X
SSDPNY XLR8 Gaming 1 TB, M.2
AiOCorsair H100i Pro RGB
NetzteilFractal Design Ion SFFX 650G
Since, according to research, there are often problems in connection with Corsair AiO wax, I have deactivated the reading of sensor data.
In the recording as a csv list, HWinfo gives me such values, for example:
Does anyone have any advice or can help?
Best regards
Jan
Check the footer in the CSV log file, does this perhaps match the columns?
It might also be helpful if you would attach the CSV log.
The problem is because you're using comma "," as the Decimal separator and also as CSV separator. This makes it impossible to interpret the CSV layout.
Try to change the CSV separator to a semicolon ";" or the Decimal separator.
