1FootInTheGrave
So I sat down at my home computer this morning, and I checked my HWinfo numbers out of habit, and I was alarmed to see that while my computer was sitting idle overnight, my CPU core voltage had apparently hit 870v, and my GPU core voltage had apparently hit 643v. Considering that my normal maximum CPU voltage is in the low 1.3's and my GPU is usually less than 1.1, seeing those massive numbers is slightly concerning.
I'm on windows 10, and I don't use sleep mode or hibernate mode, so the computer was just sitting idle on the desktop all night with the screen turned off.
My city in California had some large power outages from wildfires in the last few days, so my first thought was that there had been some type of power surge that caused my system to get hit with a huge voltage spike. I don't know if that would make sense though, since the core voltages are controlled by the computer itself. I have no idea if a power grid surge could cause my core voltages to spike like that. I also think that my PC would have gone up in flames if the CPU had in fact been hit with 870 volts. I'm currently not using a surge protector, but my (cheap) power strip says that it has protection against 500v. And yes, I will be buying an actual surge protector this afternoon.
Is it possible that this was just a computer brain-fart? I've been using HWiNFO64 for a while now, and I've never seen it make any blatant errors like this before... so if it's saying that my CPU hit 870.249v, I'm inclined to believe it.
Thanks for any input, I really appreciate it!
