I recently purchased a 'new' laptop, an open box Dell Inspiron 7586. It came with a single stick of DDR4-2666 RAM, so I decided to pull the dual channel set from my old, semi-functional laptop and put it in the new notebook. The old laptop had a pair of 8GB DDR4-2400 RAM, so I thought the memory controller would just downclock to 2400/1200 MHz, but I'd still get a much higher effective speed with a dual channel set up. That doesn't appear to have happened.
Instead the memory is showing up as a speed of 665MHz, or about 1333MHz when double data rate is accounted for. Can this possibly be right? See attached log.
Code:
Memory --------------------------------------------------------------------
[General information]
Total Memory Size: 16 GBytes
Total Memory Size [MB]: 16384
[Current Performance Settings]
Maximum Supported Memory Clock: 1200.0 MHz
Current Memory Clock: 665.2 MHz
Current Timing (tCAS-tRCD-tRP-tRAS): 10-10-10-28
Memory Channels Supported: 2
Memory Channels Active: 2
Command Rate: 1T
Read to Read Delay (tRD_RD) Same Rank: 4T
Read to Read Delay (tRD_RD) Different Rank: 4T
Read to Read Delay (tRD_RD) Different DIMM: 7T
Write to Write Delay (tWR_WR) Same Rank: 4T
Write to Write Delay (tWR_WR) Different Rank: 4T
Write to Write Delay (tWR_WR) Different DIMM: 7T
Read to Write Delay (tRD_WR) Same Rank: 8T
Read to Write Delay (tRD_WR) Different Rank: 8T
Read to Write Delay (tRD_WR) Different DIMM: 10T
Write to Read Delay (tWR_RD) Same Rank (tWTR): 19T
Write to Read Delay (tWR_RD) Different Rank: 16T
Write to Read Delay (tWR_RD) Different DIMM: 6T
RAS# to RAS# Delay (tRRD): 4T
Refresh Cycle Time (tRFC): 234T
Four Activate Window (tFAW): 16T
