Minimize Sensors on startup is not working
earl088
I noticed today that HWinfo64 Pro v7.37-4970 starts up showing the sensor windows when I do not have that setting enabled to begin with and I also have the minimize sensor on start up.
I have unticked those boxes, uninstalled the app and manually deleted the left over files on the folder and reinstalled. Still getting the same issue of the sensors showing on start-up.
earl088
Found the culprit. It seems that allowing MSI-AB to access hwinfo64's dll's seems to trigger a program start which will ignore the minimize on start settings.
If MSI AB is causing this then most likely it's starting HWiNFO64 with a different local path. Try to reconfigure the settings when launched by MSI AB and check where it stored the HWiNFO64.INI file.
earl088
When I uninstall HWinfo64 no other instance of the app starts so I believe that there is no other location. For now I have unchecked HWinfo64 from MSI AB's data source.
