Missing DIMM Memory Temp HWiNFO64 v4.39-2205
RE: Msiing DIMM Memory Temp HWiNFO64 v4.39-2205
Sorry, but I cannot see any files attached. Please check again.
Are you sure your mainboard can monitor DIMM temperatures, or your modules contain a temperature sensor (TSOD) ?
You mainboard doesn't support reading of the DIMM temperatures and your DIMM modules don't seem to contain any temperature sensor. So it's not possible to measure that.
Hello Martin,
Yes its seems my mainboard doesn't support reading DIMM Temp, I want to know which feature should my DIMM support to read Temp (not mainboard)
Memory Module Manufacturer: Corsair
Memory Module Part Number: CMT16GX3M4X2133C9
Features:
Partial Array Self Refresh (PASR): Supported
On-die Thermal Sensor (ODTS) Readout: Not Supported
Auto Self Refresh (ASR): Not Supported
Extended Temperature Refresh Rate: Not Supported
Extended Temperature Range: Supported
Module Temperature Sensor: Not Supported
And thanks for your time
It's the On-die Thermal Sensor (ODTS). If you want to buy such modules, make sure that this feature is present.
