Missing MB temp/volt/fan info between v3385 & v3390 - TR 1950x x399 Asus ZE Mboard
tcoreprime
So something got changed with some of the changes between 3385 and 3390 and dumped most of the MotherBoard info in the sensors.
I had been running 3383 for a while.. and was fine.. saw the notice about the 3390 and with the updated EVGA FTW3 sensors wanted to check it out..
well running sensors then showed me missing a whole section of my layout.
As the files show.. TR 1950x - X399 Asus Zenith Extreme MB, currently on bios 0901 -
While it will show that I have a Corsair H100iv2.. I am NOT running Corsair Link currently.. only some Corsair Utility Engine (CUE) for audio.
I also do not have the external EC mini sensor board plugged in currently either.. so while the EC is there, its sensors are blank for that reason.
Even then, prior to 3390... normal MB temp/voltages/fan speeds were showing up.
Thanks.
  • 3385-HWiNFO64.DBG
  • 3385-X399.txt
  • 3390-HWiNFO64.DBG
  • 3390-X399.txt
I think I found the problem, it will be fixed in the next HWiNFO build.
For the time being, you should be able to workaround this problem by putting the following line at the end of the HWiNFO64.INI file (open in Notepad or any other text editor):
AsusWMI=0
tcoreprime
Yep... tested that out and that works.
It also adds some other X'd out sensors.. but the other missing entries are back.
Thank you.
Thanks for the feedback. Those X'd out sensors can be easily re-enabled by hitting the Ins key on them.
