Missing temperature readings for Kingston NVMe M.2 SSD ?
hardtop
Hello! First and foremost, thanks to the devs for that great piece of software ;-)
I just built a new computer with several drives, most of which having accurate temp readings for their temperature but somehow the NVMe drive doesn't.
I'm using version HWINFO64 v6.14-3980.
I have 5 drives:
  • Western Digital M.2 SATA SSD
  • LDLC SATA SSD
  • SanDisk SATA SSD
  • Seagate SATA HDD
  • Kingston M.2 NVMe SSD
The exact model reference for the Kingston drive is : KINGSTON SA2000M8500G
For some reason, all drives except the NVMe one have temp readings :
The main screen correctly displays the NVMe drive temp though, but not under the S.M.A.R.T. list :
whereas other drives have a specific SMART temperature entry. For example, the WD drive :
CrystalDiskInfo reports the drive temperature as any other drive (WD M.2 SATA Drive and Kingston M.2 NVMe Drive) :
How could I get that temperature reading (which seems to be available to HWInfo somehow) in the sensor list, so I can use it on my sidebar gadget ?
Any clues ? TIA ;-)
HardTop
First please try to completely Reset Preferences in main settings of HWiNFO.
If that won't help, please attach the HWiNFO Debug File for analysis.
hardtop
Huh maybe I should have thought of that earlier. Resetting the parameters did the trick... Thanks Martin !
