MSI Z87 G45 Temperature readings
thegamer298
Motherboard: MSI Z87-G45 GAMING
What are the temperatures:
auxiliary- stays at 22-23c even though ambient temperatures are 26c.
auxtin1 - stays at 17c even though ambient temperatures are 26c.
auxtin3 - varies from 0c-206c.
These are all under the Nuvoton NCT6779D chip.
I believe that at least the AUXTIN3 is an invalid value of a not connected temperature input on your mainboard.
As for the others, they might be invalid as well. You might check with the MSI Command Center tool if you find a correlation between these temperatures and HWiNFO. If there are any discrepancies, please let me know and I'll fix it.
thegamer298
Thanks for that.
Command center only has one temp (other then all cpu related ones), which is motherboard, HWINFO reports that correctly.
