johnl5r3w9
Hi all,
Everything looks normal shortly after the program opens, but after several hours (leaving it running overnight while the PC idles for example), I've started to get some very strange temperature readings - see pic 1 where highlighted in blue. I've included pic 2 that shows CPU readings - everything seems normal here.
I've made sure that the PC does not sleep or hibernate during idling, everything was reset to factory optimized defaults in the motherboard BIOS settings, (no overlocks, no XMP profile), the computer is otherwise 100% stable, it passes prime95 or any other stability test with no problem whatsoever, but these temperature and voltage readings seem to suggest that something is wrong.
I tied keeping an eye on the numbers as they change, hoping to catch them changing to a nonsensical result in real time - without success. The temperature and voltage readings for the PCH, CPU, Temperature 4, VRM and Temperature 6 all appear quite normal, mostly staying within ±3 degrees under the "Current" column.
Any comments or insights is much appreciated.
