New to HWINFO and pc builds - need some help understanding the logs.
Piro
Hello Everyone.
I know this question has been asked many times in the past on this forum, however, I found the answers to be very specific to the issue of those posts (which is normal).
I have recently built my first sff pc and as far as I can tell it works (so far).
I heard that it is a good idea to stress test a PC, especially when it is new or when you make any changes to your build, so I followed JayzTwoCents How to stress test a PC to find errors and crashes YouTube video.
However, instead of using Ryzen Master, for which I have read some fairly negative comments, I decided to use HWINFO (I just installed today), which was highly recommended in different communities.
In his video he mentions looking at the CPU temp and peak speed.
For now, I haven't fully understood which CPU temp (Tctl/Tdie, average, Tdie, Core Temperature, etc...) I should be looking at, nor the Core Clocks speed (Current, Minimum, Maximum, Average).
As far as I could tell, it all seemed fine when running CinebenchR23, but I would appreciate a second opinion.
I have attached the log file to this post. Any help/information would be appreciated.
As I mentioned, my PC is fairly knew with the following parts:
  • Asus ROG STRIX B550-I GAMING
  • EVGA GeForce RTX 3080 12GB FTW3 Ultra Gaming
  • Fractal Design Lumen S24
  • AMD Ryzen 9 5900X
  • CORSAIR SF Series SF750
  • Corsair Vengeance LPX - DDR4 - 2x16
A few posts I glanced at:
https://www.hwinfo.com/forum/threads/help-understanding-logs.7109/
https://www.hwinfo.com/forum/threads/what-are-some-of-the-most-important-values-for-beginners.6916/
https://www.hwinfo.com/forum/threads/need-help-understanding-logs.5809/
  • first_hwinfo_cinebench_stresstest.zip
Piro
Hi Tom,
Thank you for having a look at my log and getting back to me.
I thought Cinebench provided GPU benchmarks, I guess I was mistaken. I will have a look at 3DMARK and come back here with the logs for that :)
Dom
For a 3080 (or any Nvidia card with raytracing), I suggest a couple hrs of Pure RT
Its based on Unreal engine 4 which is famous to be GPU stability sensitive. I usually let it run 6 to 8hrs
