I am running the latest suite of apps with Iolo's Phoenix 360: System Mechanic, Privacy Guardian, and Malware Killer. A real old version of HWINFO installed in Feb. 2019 was working fine. But after I upgraded Phoenix 360 to the latest version of all the apps, none of the HWINFO versions work. On the latest 6.07 beta for example, after installing when I click on the 64 bit app the program does not open. Or during the install of the older versions, I get a message that:
An error occurred while trying to replace the existing file
DeleteFile failed; code 5
Access is denied
As it is right now, HWINFO won't run at all on my system. I am using Windows 10 with the latest 1809 cumulative updates installed as of 5-31-19. My computer is an Alienware Aurora R7 with absolute latest BIOS and hardware drivers (I only run this computer every 3-4 months, at which point I update all the drivers and BIOS, etc. Also all the software apps like AIDA64 and HWINFO). Unfortunately, can't use HWINFO at all anymore.
Access is denied
