Hi
I recently installed hwinfo to watch temps on my rtx 3090. My card runs hot and I wanted to know if it was thermal throttling under heavy load or just running a little hot, but otherwise ok.
When I look at the GPU data on hwinfo, specifically the "Thermal Limit", I noticed it is set to 83 Celsius. After reading up on the card elsewhere that seemed like a low limit for the card to be set to throttle itself back. I was under the impression that, while not ideal at all, these cards could actually reach into the 90s even before ever having to suffer throttling and performance drops.
Is 83c a common thermal limit?
While gaming my temps tend to avg around 78 and under heavy load sit at around 80-81 celsius with an occasional spike to that thermal limit of 83.
Any help or info at all would be much appreciated. Thanks
