Hello, does the VRM sensor work in this laptop, it always shows 52 or 53 degrees, regardless of whether it is at rest or in the ts bench testing program.
No, there's nothing else I can do. This temperature is read directly from the VRM via internal CPU interface for VRM. So if the value seems incorrect, then it's a fault of the VRM telemetry.
I doubt you will find the full datasheet as such a usually restricted and confidential.
