Page Down Key Not Recognised
GAKB90
With HWiNFO64 open in Sensors-Only mode my Page Down key does not behave as expected.
It is detected in Corsair iCUE, on a keyboard testing website, but it isn't detected as a key input by any other software on Windows, whether trying to use it for scrolling or as a bound key.
This is true with my Corsair keyboard, a backup Logitech keyboard, and the Windows 10 On Screen Keyboard.
The page down key works when HWiNFO64 is closed, or when it is open in full and not in Sensors-Only mode.
  • Log File.txt
Have you maybe configured the PgDn key as a hot key for some action in HWiNFO? Check in sensor settings for possible hot keys assigned.
You might also try to completely Reset Preferences in HWiNFO to get rid of all settings.
GAKB90
That was my first thought, but Page Down is not bound to any hotkeys.
I also already tried resetting the settings, and also changing to the most recent beta version.
It's a very odd issue!
Indeed, very odd. Try to disable the "CorsairLink and Asetek Support" option in HWiNFO.
