tqskull
hwinfo says the gpu is in its thermal limit (even at average). however, a few rows above you can see that max temp was 74 degrees, that's 14 degrees away from the gpu temp limit. I'm not sure if this is a bug or what may cause this. Should this be moved to bug report or do you have any tips?
Greetings
edit: attached screenshot
Greetings
