Hello sir, after some research i've heard that Rainmeter can now use the sensors while ignoring the 12-hour limit. Is there a way for RTSS to use the sensors too without it getting disabled every 12hrs until i turn it back on? I have a custom overlay in RTSS and i used shared memory support to access Hwinfo as a data source, yes it works but it will be disabled every 12hrs sadly. I'm sincerely hoping that there would be a workaround for this like how you did with Rainmeter.
Edit: if this is not possible can you just increase the column limit for OSD(RTSS)? Currently its limited to 20. The reason being so that i can just use the sensors i want and put it more on the right side of my screen because even if i dont use shared memory support, my overlay dll in RTSS can display it to the position i want it to be.
