Hello
Recently I bought a 14”yoga 9i.MTM 82BG006KAX ,which still in the box cuz i need to have a final decision about weather to open it or not.
PROCESSOR
MEMORY & STORAGE
PROCESSOR
MEMORY & STORAGE
is this thing is real cuz that means I should sell this laptop as I mainly need it in zoom call with screen share and camera for more than 8 hours (it would probably be attached to power resource at that time ) I need it to perform well at such time..
does the comment above mean I can not use it for such a purpose ????
it has been 2 days since the laptop arrived and I still did not unbox it cuz I am really scared of such a problem
Does anyone have an idea about such limitations ????
please help me to decide
your help really appreciated
PROCESSOR
Processor Type | Intel Core i7 |
Processor Model Number | 1185G7 |
Processor Core | 4 |
Processor Memory Cache | 12 MB |
Processor Clock Speed | 3.0 GHz |
Processor Max. Clock Speed | 4.8 GHz |
Processor Generation | 11th Gen |
MEMORY & STORAGE
RAM | 16 GB |
SSD Storage Capacity | 1 TB |
Storage Type | SSD |
MEMORY & STORAGE
RAM | 16 GB |
As I found this comment on reddit which makes me really worried
The CPU is severely power-limited, to the extent that a 30-minute zoom call with the camera and screen sharing on will throttle down the CPU to 400MHz! Note that it's specifically PL1/PL2 and not a thermal limit. Specifically, it seems to cap itself to <10W at all times, and that's supposed to be a 28W CPU. I went through the hoops to uninstall and disable Intel DPTF and use ThrottleStop to fiddle with power limits. Unfortunately, 11th gen CPUs can not (yet?) be undervolted, and the thermal solution provided by Lenovo can't quite handle 28W, but I did limit it to 24W and lowered the max turbo to 4GHz, and that solved my performance problems without hitting ridiculous temps. I might end up repasting and repadding it if it gets too hot in the summer.
What I understand from the comment above it is a machine limitation not related to bios or updates!!!“
