Hello All,
Ryzen 3700X
Corsair Vengeance 32 GB RGB
MSI 2060 Super
MSI MPG x570 Gaming Edge Wifi
Corsair H100i
I have had problems with this PC in the past, getting a WHEA_UNDETECABLE_ERROR BSOD. Went to a couple places and they thought it was my CPU. Replaced the CPU, went to boot the PC, and it didn't boot. Took it to Geeksquad and they suggested trying a new PSU with the old CPU, and sure enough, it worked. Been running smoothly for about 1.5 months now, but whenever I am in games (ONLY IN GAMES, HASN'T CRAHSES AT IDLE, yet...) it just crashes. Turns off randomly with the following event logs from windows.
Event log 1
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 3/31/2021 4:45:48 PM
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (70368744177664),(2)
User: SYSTEM
Computer: DESKTOP-8F4PDNP
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>41</EventID>
<Version>8</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2021-03-31T20:45:48.7856231Z" />
<EventRecordID>9472</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>DESKTOP-8F4PDNP</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">39</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">false</Data>
<Data Name="CheckpointStatus">0</Data>
<Data Name="CsEntryScenarioInstanceIdV2">0</Data>
<Data Name="LongPowerButtonPressDetected">false</Data>
</EventData>
</Event>
Event log 2
Log Name: System
Date: 3/31/2021 11:58:33 PM
Event ID: 41
Task Category: (63)
Level: Critical
User: SYSTEM
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2021-04-01T03:58:33.4722128Z" />
<EventRecordID>9698</EventRecordID>
<Correlation />
</System>
<EventData>
<Data Name="SystemSleepTransitionsToOn">0</Data>
</EventData>
</Event>
Went to Tom's Hardware Forums to try to get to the bottom of this, since it appears that no tech store understands the issue. They suggested I download HWInfo and just keep an eye on it. Sure enough, I get into a league game, play it out, and all goes fine. Then I look over and see the PRD minimum is at 78.7%. After reading the thread posted here about PRD, and how manufactures are using it to boost benchmark numbers, I assume what is happening is my motherboard is telling my CPU it can draw more, and more, and more power until the unit just can't hold it anymore. So my old PSU was fine, but when it crashed something about the hardware would tell it to BSOD, and this new CPU doesn't use that same process so instead it just shuts off.
Edit: Just glanced at the number again when loading a reddit page on google chrome, and it briefly dropped to 88% not sure if relevant.
So my question is; is this a CPU or Motherboard problem, and what is my fix? Is this even indicative of anything needing to be fixed? I never have overclocked, and don't even touch my bios because I am terrified I will screw something up. I think the only reason you can't boil water on my CPU is because my cooler has done a pretty kick ass job of keeping temps extremely low so it doesn't heat up too much, but just draws a shit ton of power instead.
Thank you in advance!
Just got a crash, file is linked below with what HWinfo got during the crash. The first ten lines are the moments leading up to the crash and everything below that is from when I was running my PC fine.
Ryzen 3700X
MSI 2060 Super
Corsair H100i
Event log 1
Log Name: System
Event ID: 41
Task Category: (63)
Level: Critical
User: SYSTEM
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
Event log 2
Log Name: System
Event ID: 41
Task Category: (63)
Level: Critical
User: SYSTEM
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
