Preffered cores on sensors doesn't match info pane or Ryzen Master
KaosMaster
Hello! I have just observed, on a 5800x, that the "Preffered Cores" listed in the Sensors panel is not the same as the information screen or Ryzen master. The best cores are incorrect on the sensor panel next to the core indicators?
Thanks for your reply, I figured it out. Both Ryzen Master and your information window all start with the first core being 1 and not 0, so in the sensor panel it is shifted by 1 downwards. But also, the sensor panel displaying two different sets of Preffered Cores..with 2 X #1 cores just adds to the confusion even more.
If you could change one or the other so it all matches would be great.
