DellXPS159560
I have a Dell XPS 15 9560 that I repasted and undervolted using ThrottleStop. Temperatures are relatively good but the fans might turn while browsing randomly. In order to keep the fans from turning on while browsing/doing light work I am using the fan control options on HWiNFO.
I used Task Scheduler to run HWiNFO on startup, then I used the info on this thread (https://www.hwinfo.com/forum/Thread-Can-I-run-Fan-Control-at-each-startup) to start fan controls automatically when HWiNFO starts.
Everything works amazing, I can restart and HWiNFO will auto-start and be hidden in tray with fan controls on; However, if I close the lid there's a problem. When I reopen the lid, the fans turn on immediately and are at the highest speed. They will stay at the highest speed. If I manually open the fan control window and press set manual to zero, I can turn off the fans and they will stay off (until the temps go up to a point where they should go on again).
If I close the lid without the fan controls on (without the window open) and then open the lid, the fans will stay silent as they should. Is there anyway I can fix this?
P.S.
These are the settings I'm using: https://i.imgur.com/i50mKMb.png
FYI that's not my screenshot but I copied those settings.
P.S.
