Quickly enabling and disabling sensor group monitoring
ruku1994
Is there a way to enable\disable a whole group of sensors via cmd or some file edition or through win register? The problem I have is that my RTX 4090 monitoring needs to be totally disabled (whole section) when I am gaming as it will cause micro stutters every second or two. Mostly visible in high FPS situations (120+). I know it is a bug in nvidia drivers as I have already read the other topics about this issue.
In order to mitigate it I would like to have a quick way to disable end enable the monitoring when I am opening and closing a game (maybe some cmd file). Instead of having to open HWinfo and look for gpu section.
It is a shame :(
Anyway thank you for quick response. Maybe you could consider it in the future if you have time ;)
Thanks for great app.
