Hequaqua
When I try to open the Memory Timings and the other Menu items by right-clicking the icon in the task tray, not task bar, nothing.
I've rebooted several times, changed bios profiles, even tried deleting the config file and trying it again.
Very odd.
Oh, also the issue you fixed on the values showing correctly for the Core Clocks when I was using a multiplier of .001 worked correctly in 5530, the lasted Beta, it doesn't, the whole column for the Maximum shows the full values. So I'm back on 5530.
Very odd.
