electricnic
Two issues, not sure if they're related:
HWiNFO polling RTSS (standalone, not with MSI Afterburner) is limited to 1000ms, even if the rest of HWiNFO is set to 500ms. Every other sample greys out, but as of v7.63-5215, the greyed out values are reporting as zero (it used to just repeat the previous value). This is causing really ugly line graphs.
PresentMon similarly updates every 1000ms, regardless of global settings being set to 500ms, and seems to have the same behavior - every other reading is zero.
Ideally, I could get FPS, Frametime, 1% Low, and 0.1% Low every 500ms, but if this isn't possible, it'd make a better looking line plot to simply repeat the previous value as it did in previous versions of HWiNFO.
Thanks
Thanks
