RTSS OSD no longer working
Kol12
Since hooking some HWiNFO values into the RTSS OSD the MSI Afterburner values are no longer showing, only the HWiNFO values are showing. I had this happen once before a long time ago and can't remember how to fix it.
If you have those auto starting with Windows, check in Windows Task Scheduler. You can adjust delays there or create dependencies.
Neither HWiNFO or MSI AB is enabled to auto start with Windows on my machine (as per startup tab - Task Manager). The RTSS OSD is only showing the HWiNFO RTSS OSD values, the MSI AB values are missing:
Seems to be a configuration issue with MSI AB. I reset MSI to defaults and it's working again.
No idea what changed in MSI AB to cause this....
