I can't confirm the clock issues, it seems to be correct here. If you want, i can check more with you. I assume you also have the only existing BIOS for X3D CPUs, 1.64.Fresh installed Windows 11, all BIOS setting default.
Is this normal that the max. MHz is around 5300 on some cores? I thought it should be around 5700 MHz on one or more cores?
