I've noticed that when im looking at my motherboard sensor readings on the CPU reading can reach a minimum of 0c, this seems impossible
Is this a known bug with HWinfo? I see a few other old threads with similar issues:
Just wondering if this is a known issue or perhaps there is a setting i need to change? I saw on one of the linked threads there is a setting called "Invalid if" would this be a fix for me?
Thank you in advance
@Martin (and anyone else), it looks like Intel finally corrected the 0c temp sensor bug with microcode 0x1F. I'm running an MSI Z690 Edge WiFi DDR4 with an i9-12900K. This microcode revision was added to my MB's support site on MSI with the main feature of enabling i9-12900KS support.
I let HWInfo run all day, and no 0c reports whatsoever.
- ezflma
- Forum: HWiNFO® 32 or HWiNFO® 64 Bug Reports
My 12400F occasionally reports a temperature reading of 0 and this is not correct but Core Temp and HWiNFO64 both count this as part of the minimum even though they should not be counting it at all. Could there be a HWiNFO64 option to ignore temperatures of 0 just like there's one to ignore subzero temperatures?
- LoganDark
- feature request
- Forum: General Discussion
