Sensor window crashing
tophdogg
First I am attempting to get an FPS option in hwinfo to then possibly be available in ModBros software using RTSS. If this is not possible please let me know.
The issue I am having is after selecting sensor only mode, the sensor window never appears (as well as a tray icon). After some troubleshooting I have found that having RTSS open is not allowing hwinfo sensors to open. I can open summary mode fine. After closing RTSS I am able to open hwinfo in sensor mode.
I have uninstalled and reinstalled both programs. I have tried using current and beta builds of both programs.
So if RTSS is started prior to HWiNFO, launching HWiNFO will hang during opening sensors at some point? Or does it crash?
If it's hanging and you terminate RTSS, does HWiNFO continue and opens the sensors?
Please also try to "Reset Preferences" in HWiNFO if that will help.
After some more troubleshooting I found that it may have been some kind of installation error? I purged all files of each program that I could find, reinstalled both and it is now working properly.
