Session and alert
mko61
Hi all,
I have a Windows server with hwinfo running.
It start scheduled  at startup as SYSTEM, without user logon or interaction. It works fine and I can connect remotely to that instance running HWINFO on my PC.
On the server I configured an alert: it starts a program when a parameter reaches a defined value.
My problem is that the alert triggers only if I log on the server console and launch HWINFO manually. If the console is closed, the "headless" HWINFO run at startup - even if serving remote connections - does not trigger the alert.
I need to trigger the alert without loggin on: any suggestion?
Thanks in advance for any kind help.
Regards,
