Show graph for Frames per second disappeared
wawans1975
I am experiencing if started PC and play games->  No  OSD for Frames per second on screen and OSD Settings cleared for it, although I already setup OSD for Frame per second before exiting hwinfo64 > shutdown and start PC > run riva + hwinfo64 +  game.
HWinfo64 shows frame per second on windows sensor during game running but no OSD and OSD settings for it cleared, is this normal?.
thanks
wawans1975
Additional info:
1.Recently I built another PC with spec:
Ryzen 5 2400G
AB450 I A*RUS
G*BYTE RX 570 8GB Gaming ver 1.1
2. I tested MSIAB, it  enables frame rate OSD each time I started my PC and then running game, while with the same steps HWinfo64 can show frame rate in Status Windows, but frame rate OSD disappeared.
I attached debug file of HWinfo64 when can show frame rate OSD in case you need more info.
Thanks.
  • HWiNFO64.zip
wawans1975
Some how after I reset HWINFO64, now OSD for frame rate can show after PC restart  :huh:
I think problem solved for now.
