Show ToolTips in sensor settings remains selected
Renx-78
Good morning!
I wanted to report an incorrect functioning of the sensor settings.
In Sensors Configuration, if I uncheck the "Show ToolTips" function and confirm by clicking OK, the tooltips remain active and reopening the Sensors Configuration the function appears checked again.
OS: windows 11 Pro v. 22000.593
HWinfo: v. 7.22-4730
Thanks for the report! I found the bug and will fix it ASAP.
For the time being you'll need to modify this setting via the HWiNFO64.INI file entry:
SensorToolTips=0
I have re-released v7.22 as Build 4731 to fix this issue. Please re-download.
