Hello. I have seen a problem. I run with two computers. Then I use Remote Center. So I can watch the monitoring on my other computer.
I saw that it shows completely wrong. If you look at my main computer where it reads from. So the numbers are correct. But it appears completely wrong on my other computer that has Remote to it.
Vcore shows correctly on my main computer. But shows higher Volts on the Remote Computer. Then it shows Vcore 1.288 V on my main computer. Since then, it simultaneously shows 1.419 V on the Remote computer.
Then I saw yesterday that it is the same with +12V Shows 12 Volts on my main computer. But shows 144 Volts on the Remote computer.
Haven't checked everything if there are errors that show errors.
I have reinstalled the program and then the newest one. But it remains.
