sli: 2nd gpu temp missing
qbiinz
Both gpus show up, and in the window for sensors all information is listed for both gpus except the temperature for the second one. I didn't hide that setting and I can see both temps in other monitoring software so I know its there. Any suggestions?
Try to do a "Reset Preferences" from main HWiNFO settings, or "Restore Original Order" from sensor settings if that will help. Please let me know the result.
qbiinz
Thanks, Reset preferences worked. A window popped up saying that reading from that sensor might might cause higher system loads or latency issues and I could choose to not monitor that sensor or continue. Continuing allowed the temps to be read from both GPUs.
I don't remember seeing that warning before, but I must have chose to not monitor that sensor for some reason.
Thanks for the help
