Tried, no luck. I think this is just a minor bug of HWiNFO, and I suspect it has to do with the last item of that column being a section header. My developer intuition
Now that you're saying that must be it yes. My layout was like that on the 3rd one but after darkmode this has changed because of the first bar (sensors, curr, min, max, avg) got smaller.
Absolute max temp under 100% load? 90+C?
Any consideration for water/AIO cooler? I'm using one 280mm AIO but had it already from previous setup (FX8370 oced to 4.6GHz, ~200W). ZEN2 is pretty temp sensitive, cutting boost over 50C all the way up to 95C, the throttling point. Mostly on all core workloads.
My max temp is 60~62C (22~23C ambient, no case) with low/medium speed for pump/fans but I do not compare a ~90W to a ~280W CPU of course...
I was about to do that when the machine suddenly booted fine with XMP enabled so for now I'm good.
I guess I could but I value stability a lot more than incremental performance gains at this point.
I understand so far, you had more than a fair share of issues and I imagine restarts and clear CMOS's... But I'm against instabilities also.
I had my share of those restarts, cold boot issues, clear CMOS, BIOS flashbacks/BIOS upgrades my self, only trying to run MEMCLK/UCLK/FCLK at 1900MHz, but no luck. I could let it at 1866~1900MHz with maybe some rare random crashes/and restarts but wasnt worth it.
Cold boot issues gone after maybe 10+ BIOS versions (I may have tried like 25~30, beta and final).
So, my ram is rated (XMP) 1733MHz, 1.35V 16-18-18-18-36-54 1T, 606trfc etc... and had a latency score (AIDA64) of 73ns for memory.
As you can see now I'm running them XMP off, 1833MHz, 1.44V 16-17-17-17-51 1T, 416trfc (and a few other secondary timings) and dropped to 67ns. Bandwidth also increased by 5~10%. My most heavy usage is gaming and that gave me some FPS. Not that I needed a <5% more FPS but I like exploring things.
I also mess around with PBO settings (a LOT), had some gains but... Conclusion: On a 6core 3600 is a moot point. On a 32core on the other hand could be something entirely different. Low temp is the most valuable key though. Otherwise any PBO settings and gains will be diminished or gone completely.
I dont know your usage, other than gaming obviously...
I'm also looking forward to Zen 3, if only out of curiosity.
Yes, so far ZEN3 is looking impressive from what we "know"...
