I have a server with an Areca 1882 Raid controller with 60 2 TB drives connected to it (3 separate 24 disk chassis).
The layout is as follows. The 2nd column is the enclosure and the 3rd column is the slot the drive is in within that enclosure.
smartctl is able to read the SMART data from each disk as follows:
smartctl -a -d areca,${SLOT}/${ENCLOSURENUM} /dev/arcmsr0
Where SLOT if the slot within each enclosure (ENCLOSURENUM).
arcmsr0 represents the raid controller card in the server.
I'm particularly interested in reading the temps of each drive via SMART so that I can pass them onto aquasuite, which supports HWiNFO as a "software temp sensor".
At the moment, all HWiNFO is showing under Drives, is "RAID DummyDevice". It does not see any of the 60 drives.
My end goal is to be able to control the chassis fan's in the enclosures based on actual drive temps as reported by SMART.
Thanks!
Code:
9 02 Slot 01 Hitachi HDS722020ALA330 2000.4GB Raid Set #1
10 02 Slot 02 Hitachi HDS722020ALA330 2000.4GB Raid Set #1
11 02 Slot 03 Hitachi HDS722020ALA330 2000.4GB Raid Set #1
12 02 Slot 04 Hitachi HDS722020ALA330 2000.4GB Raid Set #1
13 02 Slot 05 Hitachi HDS722020ALA330 2000.4GB Raid Set #1
14 02 Slot 06 Hitachi HDS722020ALA330 2000.4GB Raid Set #1
15 02 Slot 07 Hitachi HDS722020ALA330 2000.4GB Raid Set #1
16 02 Slot 08 Hitachi HDS722020ALA330 2000.4GB Raid Set #1
17 02 Slot 09 Hitachi HDS722020ALA330 2000.4GB Raid Set #1
18 02 Slot 10 Hitachi HDS722020ALA330 2000.4GB Raid Set #1
19 02 Slot 11 Hitachi HDS722020ALA330 2000.4GB Raid Set #1
20 02 Slot 12 Hitachi HDS722020ALA330 2000.4GB Raid Set #1
21 02 Slot 13 Hitachi HDS722020ALA330 2000.4GB Raid Set #2
22 02 Slot 14 Hitachi HDS722020ALA330 2000.4GB Raid Set #2
23 02 Slot 15 Hitachi HDS722020ALA330 2000.4GB Raid Set #2
24 02 Slot 16 Hitachi HDS722020ALA330 2000.4GB Raid Set #2
25 02 Slot 17 Hitachi HDS722020ALA330 2000.4GB Raid Set #2
26 02 Slot 18 Hitachi HDS722020ALA330 2000.4GB Raid Set #2
27 02 Slot 19 Hitachi HDS722020ALA330 2000.4GB Raid Set #2
28 02 Slot 20 Hitachi HDS722020ALA330 2000.4GB Raid Set #2
29 02 Slot 21 Hitachi HDS722020ALA330 2000.4GB Raid Set #2
30 02 Slot 22 Hitachi HDS722020ALA330 2000.4GB Raid Set #2
31 02 Slot 23 Hitachi HDS722020ALA330 2000.4GB Raid Set #2
32 02 Slot 24 Hitachi HDS722020ALA330 2000.4GB Raid Set #2
33 03 Slot 01 ST2000NM0033-9ZM175 2000.4GB Raid Set #3
34 03 Slot 02 ST2000NM0033-9ZM175 2000.4GB Raid Set #3
35 03 Slot 03 ST2000NM0033-9ZM175 2000.4GB Raid Set #3
36 03 Slot 04 ST2000NM0033-9ZM175 2000.4GB Raid Set #3
37 03 Slot 05 ST2000NM0033-9ZM175 2000.4GB Raid Set #3
38 03 Slot 06 ST2000NM0033-9ZM175 2000.4GB Raid Set #3
39 03 Slot 07 ST2000NM0033-9ZM175 2000.4GB Raid Set #3
40 03 Slot 08 ST2000NM0033-9ZM175 2000.4GB Raid Set #3
41 03 Slot 09 ST2000NM0033-9ZM175 2000.4GB Raid Set #3
42 03 Slot 10 ST2000NM0033-9ZM175 2000.4GB Raid Set #3
43 03 Slot 11 ST2000NM0033-9ZM175 2000.4GB Raid Set #3
44 03 Slot 12 ST2000NM0033-9ZM175 2000.4GB Raid Set #3
45 03 Slot 13 Hitachi HUA723020ALA641 2000.4GB Raid Set #4
46 03 Slot 14 Hitachi HUA723020ALA641 2000.4GB Raid Set #4
47 03 Slot 15 Hitachi HUA723020ALA641 2000.4GB Raid Set #4
48 03 Slot 16 Hitachi HUA723020ALA641 2000.4GB Raid Set #4
49 03 Slot 17 Hitachi HDS723020BLA642 2000.4GB Raid Set #4
50 03 Slot 18 Hitachi HDS723020BLA642 2000.4GB Raid Set #4
51 03 Slot 19 Hitachi HDS723020BLA642 2000.4GB Raid Set #4
52 03 Slot 20 Hitachi HDS723020BLA642 2000.4GB Raid Set #4
53 03 Slot 21 Hitachi HDS723020BLA642 2000.4GB Raid Set #4
54 03 Slot 22 Hitachi HDS723020BLA642 2000.4GB Raid Set #4
55 03 Slot 23 Hitachi HDS723020BLA642 2000.4GB Raid Set #4
56 03 Slot 24 Hitachi HDS723020BLA642 2000.4GB Raid Set #4
57 04 Slot 01 ST2000VN000-1H3164 2000.4GB Raid Set #5
58 04 Slot 02 ST2000VN000-1H3164 2000.4GB Raid Set #5
59 04 Slot 03 ST2000VN000-1H3164 2000.4GB Raid Set #5
60 04 Slot 04 ST32000644NS 2000.4GB Raid Set #5
61 04 Slot 05 ST2000VN000-1H3164 2000.4GB Raid Set #5
62 04 Slot 06 ST2000NM0011 2000.4GB Raid Set #5
63 04 Slot 07 ST2000NM0033-9ZM175 2000.4GB Raid Set #5
64 04 Slot 08 ST2000NM0033-9ZM175 2000.4GB Raid Set #5
65 04 Slot 09 ST2000NM0033-9ZM175 2000.4GB Raid Set #5
66 04 Slot 10 Hitachi HUA723020ALA641 2000.4GB Raid Set #5
67 04 Slot 11 Hitachi HUA723020ALA641 2000.4GB Raid Set #5
68 04 Slot 12 WDC WD200MFYYZ-01D45B0 2000.4GB Raid Set #5
Thanks!
