sblantipodi
As title.
This issue happens if I connect the USB cable of my Corsair HX1200i PSU to the internal USB header
and if I run HwInfo with SMBUS enabled.
When the PSU USB is connected and HwInfo is started with SMBUS support enabled,
If I start a game or put some heavy load on the system all the USB resets, I can hear the windows ding/dong sound of devices disconnecting and reconnecting after few seconds. All the usb resets both internal and external ones.
This does not happen if I close HwInfo or if I disconnect the HX1200i power supply from the USB port.
I tried to RMA the PSU and the Motherboard for this, but with no solution to the problem.
Any idea why SMBUS makes the USB to reset?
