Mr. Fox
I have a Clevo P870DM3-G that has an issue with HWiNFO64. I don't know if maybe I am doing something that causes it with a box checked in the settings that needs to be clear, or whether it is is a HWiNFO64 bug, or a laptop bug.
If I have HWiNFO64 running (which I usually do) and use Thaiphoon Burner to read from the memory modules they show SPD checksum errors. If I close HWiNFO64 and wait a couple of minutes, re-launch Thaiphoon Burner and re-read from the sticks the SPD checksum errors are gone. I am also failing TM5 testing at 3000 CL16 pretty consistently and experience memory-related instability with HWiNFO64 running. I have EC support disabled, so it's not that part of HWiNFO64. If I do not use HWiNFO64 then the SPD checksum errors go away and I regain stability.
Any thoughts or advice about what might be the problem and whether I can fix it? I've never seen this issue on any other platform before and I use HWiNFO64 on everything. I don't know how to function without it I have been using it for so long.
