So, according to HWInfo,
B.) How can the sound device report a different speed while sitting at the same controller and shares the PCI-E link?
I wonder if this is all normal, HWInfo reports something incorrectly or the machine does not behave as I would assume.
Stripped log:
- there is a PCI-E 16x 3.0 controller with ASPM disabled running at 2.5 GT/s instead of 8 GT/s. -> Is this normal?
- on this bus, there is a graphics device running at 2.5 GT/s -> makes sense if the controller is running at 2.5 GT/s
- on the same bus (and card), there is a sound device running at 8 GT/s -> How so...?
Stripped log:
Code:HWiNFO64 Version 5.86-3480 Intel Skylake/Kaby Lake/Coffee Lake - PCI Express x16 Controller [R0] ----- [General Information] Device Name: Intel Skylake/Kaby Lake/Coffee Lake - PCI Express x16 Controller [R0] Original Device Name: Intel Skylake/Kaby Lake/Coffee Lake - PCI Express x16 Controller [R0] Device Class: PCI-to-PCI Bridge Revision ID: 7 [R0] PCI Address (Bus:Device:Function) Number: 0:1:0 PCI Latency Timer: 0 Hardware ID: PCI\VEN_8086&DEV_1901&SUBSYS_00000000&REV_07 [PCI Express] Version: 3.0 Maximum Link Width: 16x Current Link Width: 16x Maximum Link Speed: 8.0 GT/s Current Link Speed: 2.5 GT/s Device/Port Type: Root Port of PCI Express Root Complex Slot Implemented: Yes Hot-Plug: Not Capable Hot-Plug Surprise: Not Capable Slot Power Limit: 75.000 W Emergency Power Reduction: Not Supported Active State Power Management (ASPM) Support: L0s and L1 Active State Power Management (ASPM) Status: Disabled L0s Exit Latency: 128 - 256 ns L1 Exit Latency: 4 - 8 us Maximum Payload Size Supported: 256 bytes Maximum Payload Size: 256 bytes [System Resources] Interrupt Line: N/A Interrupt Pin: INTA# [Features] Bus Mastering: Enabled Running At 66 MHz: Not Capable Fast Back-to-Back Transactions: Not Capable [Driver Information] Driver Manufacturer: INTEL Driver Description: Intel(R) PCIe Controller (x16) - 1901 Driver Provider: INTEL Driver Version: 10.1.7.3 DeviceInstanceId PCI\VEN_8086&DEV_1901&SUBSYS_86941043&REV_07\3&11583659&0&08 Location Paths PCIROOT(0)#PCI(0100) PCI Express x16 Bus #1 ---------------------------------------------------- MSI GTX 1070 Sea Hawk EK X ------------------------------------------------ [General Information] Device Name: MSI GTX 1070 Sea Hawk EK X Original Device Name: NVIDIA GeForce GTX 1070 (GP104-200) Device Class: VGA Compatible Adapter Revision ID: A1 PCI Address (Bus:Device:Function) Number: 1:0:0 PCI Latency Timer: 0 Hardware ID: PCI\VEN_10DE&DEV_1B81&SUBSYS_33081462&REV_A1 [PCI Express] Version: 3.0 Maximum Link Width: 16x Current Link Width: 16x Maximum Link Speed: 8.0 GT/s Current Link Speed: 2.5 GT/s Device/Port Type: Legacy PCI Express Endpoint Slot Implemented: No Emergency Power Reduction: Not Supported Active State Power Management (ASPM) Support: L0s and L1 Active State Power Management (ASPM) Status: Disabled L0s Exit Latency: 256 - 512 ns L1 Exit Latency: 8 - 16 us Maximum Payload Size Supported: 256 bytes Maximum Payload Size: 256 bytes [System Resources] Interrupt Line: N/A Interrupt Pin: INTA# Memory Base Address 0 DE000000 Memory Base Address 1 C0000000 Memory Base Address 3 D0000000 I/O Base Address 5 E000 [Features] Bus Mastering: Enabled Running At 66 MHz: Not Capable Fast Back-to-Back Transactions: Not Capable [Driver Information] Driver Manufacturer: NVIDIA Driver Description: NVIDIA GeForce GTX 1070 Driver Provider: NVIDIA Driver Version: 24.21.13.9882 (GeForce 398.82) Driver Date: 30-Jul-2018 DeviceInstanceId PCI\VEN_10DE&DEV_1B81&SUBSYS_33081462&REV_A1\4&2D78AB8F&0&0008 Location Paths PCIROOT(0)#PCI(0100)#PCI(0000) NVIDIA GP104 - High Definition Audio Controller --------------------------- [General Information] Device Name: NVIDIA GP104 - High Definition Audio Controller Original Device Name: NVIDIA GP104 - High Definition Audio Controller Device Class: Mixed mode device Revision ID: A1 PCI Address (Bus:Device:Function) Number: 1:0:1 PCI Latency Timer: 0 Hardware ID: PCI\VEN_10DE&DEV_10F0&SUBSYS_33081462&REV_A1 [PCI Express] Version: 3.0 Maximum Link Width: 16x Current Link Width: 16x Maximum Link Speed: 8.0 GT/s Current Link Speed: 2.5 GT/s Device/Port Type: PCI Express Endpoint Slot Implemented: No Emergency Power Reduction: Not Supported Active State Power Management (ASPM) Support: L0s and L1 Active State Power Management (ASPM) Status: L0s and L1 Entry L0s Exit Latency: 256 - 512 ns L1 Exit Latency: 2 - 4 us Maximum Payload Size Supported: 256 bytes Maximum Payload Size: 256 bytes [System Resources] Interrupt Line: N/A Interrupt Pin: INTB# Memory Base Address 0 DF0FC000 [Features] Bus Mastering: Enabled Running At 66 MHz: Not Capable Fast Back-to-Back Transactions: Not Capable [Driver Information] Driver Manufacturer: Microsoft Driver Description: High Definition Audio Controller Driver Provider: Microsoft Driver Version: 10.0.17134.1 Driver Date: 11-Apr-2018 DeviceInstanceId PCI\VEN_10DE&DEV_10F0&SUBSYS_33081462&REV_A1\4&2D78AB8F&0&0108 Location Paths PCIROOT(0)#PCI(0100)#PCI(0001)
