makina69
[font=Tahoma, Verdana, Arial, sans-serif][size=medium][font=Tahoma, Verdana, Arial, sans-serif]Good forum I am new and I'm looking for a solution that I can not find anywhere I have a z170 xpower gamming titanium, the issue is that when I switch from fixed voltage to adaptive voltage, I get those errors that I see in the red boxes and I do not know what to do I must have an i7 7700k delid with fixed voltage all right but when i use the same configuration and i put it with adaptive they leave those errors that are not due to them, thank you very much.[/font][/font][/size]
[font=Tahoma, Verdana, Arial, sans-serif]adaptative [font=Tahoma, Verdana, Arial, sans-serif]The cpu does not work at 5.3ghz either[/font][/font]
[/font]
override [font=Tahoma, Verdana, Arial, sans-serif]The cpu works at 5.3ghz[/font]
[/font]
