System Tray Icon Remembrance
Splic
Whenever I restart the application or my computer, the program forgets all of the items that I added to the system tray.
I assume this is not normal; it would seem tedious to have to add & customize each item after every restart.
I am running the program in sensor-only mode and have everything set to show and minimize on startup. It's also set to remember preferences and auto start and I even checked the box for persistent driver, thinking this might be the issue. None of the settings fixed the problem and I didn't see anything about it on the forums / google.
How can I get the program to remember my system tray items?
Thanks in advance.
Try to open the sensors window and click the blue X button in the bottom right corner. That will close the application and all settings will be saved.
Splic
That was an easy and effective solution - thank you!
Follow up question: is it possible to remember the order in which the icons are arranged on the system tray? When I restart Windows, they are shuffled around.
Thanks again for such a quick response - I'm loving the application so far.
The way how those icons are ordered in tray is a matter of Windows and applications (like HWiNFO) cannot control it.
Right-clicking no the taskbar and then Notification area->Customize will allow you to define appearance of those icons, but I haven't found a way how to specify a fixed order.
