I downloaded TEMPLCD 1.03 and it says I need hwinfo to display the cpu temp on the motherboards post code lcd. It also says it could display other values that has 2 digits in hwinfo
It's in the Settings (not the Sensors settings, but the Settings entry under the Program menu in the Main window) as Shared Memory Support. Unless you have the $25 version activated, it will only function for 12 hours at once.
Hi I have that shared memory support option checked…I was wondering how can I use hwinfo to assign different values on the mobo post code debug like gpu temp? Apparently the templcd can display any 0-99 values
