cCXTAij2ja5jPw0x
When using the Sensor Status view, I have 10 or so charts on screen for core temps, CPU usage, core ratios etc.
If I enable Auto Fit on some of the charts (not sure if it just requires one chart to be auto fit, or many), the app eventually freezes, usually after some sustained high load on core 0, requiring me to kill it in Task Manager.
I have not seen this issue when I disable Auto Fit on all of the charts.
I thought it might be related to having a chart of core temp average, and a systray icon for the same value, but removing the systray icons results in the same behaviour. Disable Auto Fit is the only way to keep hwinfo stable
I'm going to try enabling Auto Fit on just one of my 10 charts and seeing if that causes the errant behaviour.
Will a debug file help you diagnose this?
Thanks, you make a incredibly useful tool!
