MKANET
I upgraded from an older version of HWinFO which perfectly displayed the value for Core Distance to TjMAX value on my Intel Core i7 13700K CPU. As soon as I upgraded to the latest version v8.20-5640, this sensor no longer displays any values at all. I noticed there are some other sensors that also don't have values either that used to work just fine in the older version. Do I need to revert back to the older version or is there a way to force these sensors to start working again?
I just paid for the upgrade to only find out that this latest version broke several of my sensors that used to work just fine. I regret upgrading and paying money for the new version.
I dont even know why I upgraded. Whatever the issue, can you please fix this? I need this sensor to work like it did in the older version.
I am certain that monitoring is enabled. Logging is disabled for performance reasons. What is the latest version should I downgrade to in order to restore these sensors back to working status?
I'm running the latest version of Windows 11 Pro.
